AIR RIDES are IN!!!
the shop that did the work put it on there website.. heres the link.
i'll take some pics of the car adn the gauges this weekend!
http://www.hzemall.com/our_gallery/i...camaro/cover.htm
changing the air pressure in the bags simply changes the springrate of them
the car can go waaay lower then 2 inches. and you can alter the ride height when the car is moving.
What controller did you get for it... the digital ride Pro? Is each corner adjustable independently? Man I really wanted to put my old camaro on air. Never had the money to get it though. Wicked setup.
Raising the car is done by adding pressure, so the "springs" are more firm, which is how they hold the car up. But, lower it to get a good stance and CG height, and you have to let air out and soften them up.
They claim you can adjust firmness and ride height, and you can. Just now how one would want or expect.
From those aspects alone, I like the air ride systems a lot. It's mainly the unknown spring rate at ride height and the shock valving that concerns me as I have no idea if it can be made to handle really well.
Amit, what can you say about the suspension feel?
I also saw some air ride shocks for our cars for about $525 a pair. Half the price of the Air Rides. I think they use a different brand shock. I'll look it up and post back.
Spring rates are unknown and change related to air pressure. The shocks are poor as they have the same kind of not so hot adjustment as QA1 and Strange shocks to which is not velocity sensititve. Frankly I'm sure the guts of the fronts shock are one of those two. Again, not gas-charged with leads to oil foaming and shock fade and that's made worse here because of airbag insulating and surrounding the front shock. I'm not much for being able to adjust height on the move anyway, but every time you change the height you are altering your alignment. And here's one. Ride. If you have a known weight of car, and you want a certain ride height you need a certain spring rate to get it and it doesn't matter whether the springs are air springs or coil springs. Note that there cars out there with "air suspensions" and coil spring suspensions as options. The performance minded Mercedes Benz use more standard suspensions.
Air suspensions have a purpose, looks. If that's what you're after that cool. But for technical, make the car work purposes, I'll pass.
YMMV, but you should know the details before laying out lots of money. And FWIW, coil-spring cars don't ride bad. Bad coil spring rates and even more importantly poor or inadequate shock ride badly.
https://ls1tech.com/forums/showthrea...04#post7962704
