Tubular Front end and Weight?
The stock front K member weighs something like 52lbs. The BMR tubular one will run you about 25-26lbs. Looks a helluva lot better and weighs half as much. Congrats.
Ryan
Ryan
Wheels up Director
You'll drop around 45-47 lbs if you get everything, k-member, lower a-arms and upper a-arms. If you're doing this strictly for weight reduction I would pass on the upper's since you save only 3 lbs total plus you need to buy the upper joints that cost me $49 each <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" />
LAter <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
<small>[ September 27, 2002, 06:48 PM: Message edited by: Bob2of3 ]</small>
i have k-member, a-arms upper & lower, and if the k-member has built in engine mounts and hal shocks it should be even less. It is amazing how much weight F-body's can lose if you look had <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" />
