How to remove ABS
Old 10-28-2002, 07:29 PM
Larry's Avatar
Default How to remove ABS
The Colonel says it is a 9 pounds weight saving to remove the ABS controller. Has any done this and if so how do you connect the lines?
Old 10-28-2002, 08:42 PM
PaiN's Avatar
Default Re: How to remove ABS
Larry I've had this done for a loooong time. Thought you'd seen it on my car.
Linelock with ABS delete that "1 Bad Z" installed for me
Maybe after the thunder shootout I can run the car by.
Also...it varies depending on the channels you have...3 vs 4 channel
