Chassis-mount Spohn Torque Arm...anything special I need to do to install it?
I'm going to be getting a Spohn TA with the remote (non-tailshaft) mount. Do I need to verify the pinion angle or anything special like that, or can I just bolt it in?
Just checking. Thanks.
Mark
Mark
Re: Chassis-mount Spohn Torque Arm...anything special I need to do to install it?
It comes with everything needed to do it including the piece to read the angle.You might need to get some longer bolts as stock ones are a tad bit short.They will work but could be a little longer.Also raise the car and let the rearend hang so as to be able to get the bolts out and back in.
