f-bodys with stock z06 rear wheels...tire rub/spacers?
Guys with f-bodys with stock z06 18x10.5 with 295 35's on the rear...do you only get tire rub on the inside of the wheel well? or also on the fender?
Are you running spacers? What size spacers?
With spacers do you still get any rub? if so...where?
-thanks.
<small>[ December 08, 2002, 03:36 AM: Message edited by: SSpray ]</small>
-thanks.
I'm running 18X10.5's in the back on G2 Super Springs. I only rub the inner wheel well under HARD turns. I've gotta be just ***** to the wall and then they rub. I'm getting a G2 Adj. Panhard rod which should eliminate this. If you're on stock suspension, I couldn't imagine there being any rubbing issues.
