why do i need a tourque arm?
the lower control arms keep it in place front to back
the torque arm keeps the axle from rotating
its really a pretty good design and works well... the only thing that sucks about it is that the torque arm is anchored to the transmission and theres nothing you can do about it that doesnt sacrifice comfort
the only other thing i would change about the design (aside from going IRS) is give it a watts linkage instead of a panhard bar. but a good rod end phb is good enough.
There are many ways to do an IRS and some are way better than others. Compare an old jaguar rear to a recent corvette rear if you just want to see how different they can be. The IRS cobras are at a significant disadvantage because the car was intended to be solid axle.
that being said, if you want a strictly drag race car a solid axle is the way to go especially for strength. A retrofit IRS would not be suitable for reasons mentioned above. but for a street car that sees bumpy pavement and is meant to do all things well... IRS is the way to go. every serious performance street car from vettes to porsches to mclaren F1's has an independent rear.
But if you want to get your f-body to hook better, there are ways. A shorter torque arm and sticky tires and the right springs and shocks will go a long way towards getting power to the pavement.
As far as the g-body cars are concerned, the baddest g-body of them all (GNX) had a torque arm, so GM saw some benefit to it.
