What are the pre-cautions for weld-on relocation brakets installation?
Anything I should be aware during installation?
Because once welded can't go back!
Please make some input
Thank you <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Make sure they are lined up correctly. I got bolt ons. You can always weld boltons later on if you prefer, at least you would know they were on right.
I do not agree with the last post. As long as the top hole lines up with the stock hole, weld them.
Moderator
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
What do the brackets use to set the angle?
You could have the holes lined up, but still
get some angular slop / difference between
sides in the vertical, fore-aft plane. I'd say
to weld with the weld-ons bolted in place (at
least to tack) and trued up angularly (however
it is you're supposed to do that).
What I would worry most about (DIY) is weld
quality. Which is partly just metal prep and
settings but has a skill element as well.
I would do a bunch of practice beads, in
the same position (welding overhead, or
anything other than workpiece-down, is a
different game). Be ready to get it right.
Speaking of metal prep, get bright metal for
1/2" about the eventual bead center. You can
blow through paint and dirt with the arc, but
you won't have ultimate weld quality without
nice, clean metal.
nice, clean metal.
