The best lowering kit for Ls1?
Thanks for your advice.
Tim.
You will get about 5000 different answers on this one.
I am running a Stage 2 lowering spring kit from H&R. Available through www.tirerack.com. I like the fact that it has "tender springs", it is 2 springs in one. The tender spring is a series of tightly wound coils that are complete compressed once the weight of the car is on them (effectively a spacer), but expand to take up any slack if the suspension is unloaded (like hanging with the car on a jack), this keeps the springs up in the perches where they belong (and it makes them slightly more difficult to install).
It lowered my 2002 Z28 about 1.3-1.4 inches.
Good luck.
I have the ground control adjustable springs, to me they are the best thing ever, you can lower them all the way and be dropped about 3 inches, or go all the way for about stock ride hieght fairly easily.
way to go my friend, way to go
i'm sorry i found out about this thing so late
Front ride height coil over kits
Rear ride height adjustment kit
