Is this a good slick/skinny combo?
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
I need a set of slicks/skinnies for this season, is this a good setup?
- M/T ET DRAGS 26X10X15
- Weld Prostar XP slick
- Weld Prostar XP skinnys 15x3.5
Would you have any other suggestions? These would ONLY be used at the track. Also, would I need to grind down the calipers to get these to fit properly? Will I need anything else to get these to fit?
You'll have to grind with 15s, but if you are going 15s dont get the XPs, I think they are the heavier version mainly used in 16" or higher
