Whats the diff. between these swaybars
Are BMR's Hollow?
Are BMR's Chromly?
Just woundering if its worth the extra money or will SLP's 1LE set do me good.
All I want is to be able to hold my own on the street for now I hope to get into RoadRacing when I get back to the states but for now I have enough fun blasting around the roads and pissing off Brit's <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
come on guys???????????
I have some money but I need to know if I should save some more.
<img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" /> <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" /> <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
To answer your question about the BMR bar, I think it is a solid bar. It would be stiffer than the hollow SLP 32 bar{all things being equal other than solid/hollow}. The ST35 is also solid. There is nothing wrong with the SLP bars. But there might be better options out there.
Oops, messed up. I was actually meaning 35mm when I said 36mm, sorry bout that.
Thanks again
As a side note, when you add stiffer lowering springs, you increase roll stiffness. I prefer to tune a car with more spring and less "bar" in order to keep the inside tire planted a little more firmly....but I may change that after I get the stickies on it this year.
Just my $.02
Good luck.
To the original question, for the street the 1LE bars will be all you need, maybe try just the front first.
Verdict? "Go for it Rock."
Jason
