Traction mod
Old Jan 26, 2003 | 09:17 PM
Ackattack's Avatar
Default Traction mod
Ok, I have BFG DRs and I was still spinning pretty bad the last time I went to the track. I'm not changing to ET Streets, so that's not an option (The DRs are still new)
So what would help my launch out the most? (Besides a better driver <img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" /> )
I kinda have an idea, but wanted to hear other's opinion.
Old Jan 26, 2003 | 09:37 PM
DONAIMIAN's Avatar
Default Re: Traction mod
TQ arm, LCA's, PHR, Relocation brackets. Other that thoes 4 things, all you can do is practice your launch. <img border="0" alt="[driving]" title="" src="graemlins/gr_driving3.gif" />
Old Jan 26, 2003 | 09:55 PM
alexWS6's Avatar
Also SFCs, Drag springs/shocks, H.D. rear swaybar, and !front swaybar. every little bit helps
Old Jan 26, 2003 | 10:18 PM
Ackattack's Avatar
which one should I do first? I can't do them all at once. The boss (aka wife) won't let me spend that much at once.
Old Jan 26, 2003 | 10:20 PM
Torqued's Avatar
I am in the same situation as Ackattack and need more traction. Of the products listed which three would be the most effective?
Thanks.
Old Jan 27, 2003 | 05:36 AM
RedJuice's Avatar
i would probably do LCA's and the drag shocks/springs first. LCA to help ward off the wheel hop and the springs/shocks to increase weight transfer off the line. Taking the front sway bar off at the track probably wouldnt hurt either.
How much PSI are you running your BFG DR's at?? (this could be your problem too)
Old Jan 27, 2003 | 07:37 AM
Ackattack's Avatar
I started out around 25 psi, and went down to 18 if I remember right.
Old Jan 27, 2003 | 05:30 PM
RedJuice's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Ackattack:
<strong> I started out around 25 psi, and went down to 18 if I remember right. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">What RPM are you launching from? Are you feathering the clutch out or just "slamming" it into gear?
BFG's dont need asthma (sp) inducing burnouts, how are you warming the tires up? To much burn out can hurt your launches with these tires.
Old Jan 27, 2003 | 06:22 PM
Ackattack's Avatar
let's see...i think I was launching about 2000 - 2500 rpms by pretty much dumping the clutch (I think that is my problem, and I've been working on that on the street). I did a quick little burnout maybe a second or two.
Old Jan 27, 2003 | 07:35 PM
FastMover's Avatar
You need to do a bigger burnout. Get them smoking and then you are good to go.
Jim
Old Jan 28, 2003 | 06:17 AM
RedJuice's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by FastMover:
<strong> You need to do a bigger burnout. Get them smoking and then you are good to go.
Jim </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">This is a possibility however, dumping the clutch isnt ideal either. You work on your launch, i stall higher 3000-3500 and then release the clutch in a slow motion just enought to get it rolling then walk it all the way out. I have a feeling if you work on your clutching you wont have any problems with the tires/traction issues.
Old Jan 28, 2003 | 11:28 PM
Iv_z28's Avatar
DR's and spinning, even if you dump it - at only 2-2.5k it shouldn't matter if you release is slowly or dump it. ..you should just bog. I'd say track prep probably sucked and/or you didn't do any meaningfull burnout. I wouldn't waist hundreds of dollars on suspension at this point.
Old Jan 29, 2003 | 03:10 PM
mf2kta's Avatar
before you throw any more money at your car, you should just learn to launch it. go a couple of times with regular street tires if you haven't yet. learn to launch on those, then take advantage of the drag radials. right now you are bogging terribly or spinning through second gear. i'm not a professional, just tryin' to help a brother out. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old Jan 29, 2003 | 03:16 PM
chirpin2ndls1's Avatar
Yeah. work on the launch. same problem that I have. I either bog or spin. sucks because I have yet to get the feel for that middle ground area. I ran a best ET of 13.333 with a 2.3 or 2.4 60' and thats on a street tire. I my trap speed is just shy of 108, thats a 12 sec run right there as long as i can launch right. Dont get sucked into the compensate lack of driving tech with more mods. its easy to do that! work at it and you will hit 12's and when you do that with skill it will feel better than having paid for it! <img border="0" alt="[driving]" title="" src="graemlins/gr_driving3.gif" />
Old Jan 31, 2003 | 02:32 PM
megathumpzillaX's Avatar
HALS !
Old Feb 1, 2003 | 07:59 PM
99OrangeSS's Avatar
Definatly do a longer burnout. Around 5 seconds or until you see a little smoke.
