Autocross Tires?
IMO, Kumho is the best bang for the buck. They are about half price of Hoosier and last about twice as long.
<small>[ February 10, 2003, 05:56 PM: Message edited by: SSmokem02 ]</small>
The heat cycling is a good idea, the tires will last longer. You can, however, do it yourself.
You need to be able to get out on the road & get them hot (like run at 80 or so for a bit). Then take them off & let them sit for at least 24 hrs before running them at the track.
I run them not shaved.... they'll build up a bit more heat due to tread squirm, but you'll have a bit longer overall life.
Use the 265/45/16s on those wheels. that's what's on the car in this photo.
Gordon
www.provenperformanceconcepts.com
<img src="http://www.provenperformanceconcepts.com/PPC%20BANNER%20468x60.jpg" alt=" - " />
<img src="http://www.provenperformanceconcepts.com/WMC082302%20052MED.jpg" alt=" - " />
kumho web site
Also
"I run them not shaved.... they'll build up a bit more heat due to tread squirm, but you'll have a bit longer overall life."
This is an incorrect statement. You'll have less tire life if you DON'T shave your tires. The "tread squirm" causes the tire to tear at the base of the tread causing chunking.
