Which one weighs more? LT1 or LS1 front brakes?
Which weighs more? LT1 or LS1 front brakes? The LS1's are bigger but I heard they are lighter? I am talking about the caliper, spindle, rotor and pads. If they are lighter that just makes me want them for my 94 Z28 even more. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Re: Which one weighs more? LT1 or LS1 front brakes?
I am getting them for sure then! I just hope going with a different kind of rotor dosent add too much more weight and negate the weight savings.
each front complete assembly minus the upper and lower control arms weigh:
LS1=48 lbs
LT1=53 lbs
This confirms the above statement of a total of 10 lbs overall loss of changing over to LS1 brakes.
LS1=48 lbs
LT1=53 lbs
How are they lighter? The rotor is bigger so you would think they would be heavier? Is what the caliper is made out of the reason? I dont think the LT1's are aluminum so if the LS1's are, that would explain the weight savings.
Different materials used. The rotor itself s heavier. Other components make up for the difference.
These weights are accurate, I have both sets here in my shop in which I use as mock-ups for setting up bogart rims when I spec out custom work for prototype rims.
Steve
Steve
