What Tires for MY Set-up?
You can see in my sig what I have. I`m thinking of maybe 16x8-8.5 with 26/11.5/16 on the rear( do I have to grind with this size?) or run 15x10 with 26/11.5/15`s. I don`t know what brand that is best for my money, rim wise. Also will E/T streets hold up to my power? I plan on buying some pretty quick.The nitto`s don`t like me at the track! Please help!
Restricted User
With your setup, ET Streets are pushing it. Go with some ET Drags or Hoosiers on a 15" rim for a little more side wall. Convo Pro's are nice because you don't have to grind your calipers. Go with some skinnies up front to obtain your best ET. Hope this helps. I run Convo Pro 15x7.5 with 26x10x15 Et Drags in the rear and Convo Pro 15x4 with 165/15 metric radials up front...
