Popping noise from new swaybar?
now everytime you go over a bump or anything it makes a kinda loud popping sound..the swaybars came fomr LGM....is this normal or did i screw up somewhere ? even though its pretty straight forward
With the car sitting on the ground, look all around the sway bar to see if its hitting anything (you may not have it centered or the endlinks may need to me shortened).
My guess is that the ends of the bar are sitting too close to something and as the suspention moves they hit.
What did you use to lube the mounts? If you don't mind redoing it, get some anti-seize compund instead of grease. Anti-seize is much slicker so it will alow the bar to turn more easily and it also will not wash off so you won't get sqeeks in 6 months.
Chris
Chris
thanks camaroguy....the sway bar looks off centered and to the left some but its coming off tonight..the guys in the road racing section dont seem to like bigger rear sway bars and they probably know more than me when it comes to it...thanks for all the help
