Does this sound like a good clutch set-up to you guys?
The Spec stage III (not sure carbon, kevlar, or ceramic), with the McCleod adjustable master.
Now correct me if I am wrong (most likely).. It comes with a new slave cylinder, and billet flywheel. I was told before that in the stage III package.. a new slave and flywheel are included.
Also if you don't mind explaining.. what is the diference between kevlar, carbon, and organic as far as perfomance/reliability.
If you don't like or the package makes no sense.. then tell me what you would do?
Thanks
Thanks
Re: Does this sound like a good clutch set-up to you guys?
I got a spec stage 3 came with new flywheel cost was around 520$ did not come with slave or master cylinders the slave cost i think is around 260 and master is about 150 cant help with different materials. maybe that will help alittle.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by 14u2nv:
<strong> If I were you I would get a RAM clutch. Ram backs its products 100 %. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Who carries Ram clutches?
I dont know about ls1 ram clutchs but i bought a ram for my 95 trans am you had to grind bellhousing for clearence you had to grind the thickness of the fly wheel down untill you got it right because they didnt know how much to take off the fly wheel. so i shipped it back and got a direct bolt in from another company. but the ls1 set up could be a better deal.
