Proper grease for poly bushings?
I couldnt find the marine grade grease that is recommended for my UMI control arms and Pan hard bar. Instead I found Lithium multi purpose grease. Is this ok to use on my poly bushings? What about using a little smear on the rod ends?
I've been using synthetic grease from valveoline I believe, the stuff is a wierd purplish color. The spohn instructions said for poly bushing to use a synthetic grease without petroleum in it.
Autozones must be lame in central valley CA, I've never seen a Energy Suspension brand grease.
