sway bar spacer kit for a moser 12bolt
Re: sway bar spacer kit for a moser 12bolt
the car already has a rear sway bar on it along with 2 clamps that hold it in place should i need to purchase another set or is the one on there good, i assume since theres a sway bar with brackets holding it to the moser another set of brackets wouldnt be necessary
thanks
thanks
I have a new unused swaybay relocation kit from Spohn that works for Moser. I paid $65 for it but will let it go CHEAP. email me at daveschott@hotmail.com if interested.
I got the BMR kit for the Moser rear without the bushings or endlinks. Works pretty well. I didn't get the bushings or endlinks b/c I already had a BMR swaybar with them. I did however end up getting slightly longer endlinks 3 3/8" to realign the swaybar to the rear LCA's (the Moser does drop the swaybar down a little).
Chris
Chris
