Brake install questions.... fluid and SS lines
Ok i ordered new disc and pads all around. I also got some of those SS lines. Heres my question. Is there anything special i need to know about these brakes to do those line and flush out the system. Like the ABS funtion, does that affect anything. I have a buddy whos gonna help me out, but he and i wanted to know if there was anything particular to look out for. If anybody knows of a good tech article on brake install and bleeding lines stuff like that i would love a link. Thanks in advance.
If you have decent mechanical ability, then line replacement will be a piece of cake. Doesn't take anything special if you are careful and don't get in a hurry.
I would consider getting a set of line wrenches to keep from rounding off the fittings.
Also, do one line at a time to keep from draining down the master cylinder. If you do that, then you will have a really bad day.
