ABS INOP Light is on!
Old 08-15-2006, 05:13 PM
BirdmanLS1's Avatar
Default ABS INOP Light is on!
Hey, ever since i installed my headers, I have had an ABS inop light on at the lower left hand side of my console. I would love to know why that is... Anyone have a clue?
Old 08-15-2006, 07:35 PM
Roarin_8's Avatar
You could hook it up to a scanner and see why. My harness went kaput and I'm waiting on a new one.
Old 08-15-2006, 07:48 PM
BirdmanLS1's Avatar
a scanner at a dealership? do they even work on modded cars? lol.
Old 08-16-2006, 12:29 AM
Roarin_8's Avatar
A performance shop would have one as well.
Old 08-16-2006, 08:53 AM
zspot98's Avatar
I would check all the ABS connections and make sure that something didn't get unpluged. Also there's an ABS wire on the passenger side down by the headers, might want to make sure that the new header didn't burn through that wire.
Old 08-16-2006, 02:12 PM
blown 346's Avatar
What he said^^^^. Usually if you dont have any fire retardent material on the wires the heat from the header will melt them.
If you go to a dealer they will charge you a arm and a leg to scan it.
Go to Auto Zone, they will scan if for you for free with a print out of the code and what it means.
You can also buy the scanner they use to bring up codes and clear them. I got mine for $125 2 years ago.
Old 08-16-2006, 04:12 PM
35thls1ss19's Avatar
if im not mistaken abs has its own computer adn it cant be scaned useing the ob2.
Old 08-16-2006, 04:41 PM
Roarin_8's Avatar
The shop scanned mines to see what was wrong with it.
Old 08-16-2006, 05:01 PM
Gun5's Avatar
i put in a posi with no speed sensor ring recently thats why my abs is in-op.. owell time to pull the light but still its still "ABS equipped" par my insurance company
Old 08-16-2006, 05:10 PM
1badragtop's Avatar
Why not just put a sensor ring on the posi? I did and was only like $30 from dealership.
Old 08-16-2006, 10:40 PM
BirdmanLS1's Avatar
Ok, I will go to auto zone and see if they can find the problem. Where is the ABS sensor that could have been melted off by the heat? That is probably what it is.
Quick Reply: ABS INOP Light is on!
