front brake swap?
front brake swap?
is it worth it to convert the front brakes on an f-body to the vette brakes?
ive read conflicting opinions on this and considerind a front break upgrade and going this route makes good $$ sense if its a worthwhile swap.
What is your intended application? I understand the OEM calipers are OK, but the rotors should be upgraded!
DD, autocross, drag, general touring?
You are correct in that many have upgraded to the C5 conversion, but for my usage, I cannot justify the cost. I had all (4) calipers polished, installed new slotted zinc-plated Brembo rotors around, and went w/HPS Hawk pads for approx $760 ($200 for polishing and $80 install)
Material costs $480, so maybe this can be a starting point, since I do not know how much you plan on spending for your conversion.
Semper Fi
Semper Fi
i had a person tell my that the f-body calipers are better then the vette's and that the real advantage in the swap is the larger diameter rotors.
my intentions are just for better everyday breaking and for the occational track day(2-3 times a year).
The larger rotor is helpful and it's a better caliper. Also, you can get C5 rotors for about $18 or so, F-body rotors are a good bit more expensive.
