Brake lights on at WOT?
Old Aug 24, 2006 | 10:55 AM
JKDZ28's Avatar
Default Brake lights on at WOT?
Today I discovered that my brake lights come on at WOT.
I didn't notice if the brakes were accually grabbing or not, but the lights come on everytime I go WOT.
I did a search and couldn't find much, but there are a couple other cases.
The car has powerstop rotors and hawk pads that work flawless.
What would be causing this and what do I need to do to fix it?
Old Aug 24, 2006 | 12:22 PM
ErikElvis's Avatar
Mine was doing the same exact thing at the track. I thought I was accidently hitting them. Ive heard they do that sometimes oon their own. the brakes arent beinghit but something to do withtraction control. I would like to know more too.
Old Aug 24, 2006 | 12:41 PM
jimmyblue's Avatar
Moderator
I thought it was supposed to be the hazards
Could be the brake switch on the pedal is a
bit sloppy, or a chafed wire shorting somewhere.
Old Aug 24, 2006 | 04:05 PM
JKDZ28's Avatar
I'm going to try to adjust the switch on the pedal back a little bit and see how that goes.
Maybe that will cause the light not to come on so easy.
I'll let you guys know how that goes.
Thanks for the advice guys!
Old Aug 24, 2006 | 04:11 PM
keliente's Avatar
Lots of people have this problem. I thought it was because they were hitting the brakes while shifting...but when I think of it, it would make sense that during a shift (which can be a little rough) perhaps the car slumps forward, moving the brake pedal onto that switch and triggering the light. Never seen an A4 do it.
Old Aug 24, 2006 | 08:38 PM
JKDZ28's Avatar
Yeah, I'd say its from the shifting.
But, when I go to shift the light flickers off and once its hammered again the lights go back on.
Go figure.
Old Aug 24, 2006 | 08:51 PM
ErikElvis's Avatar
Go figure.
Mine was/is doing the exact same thing. Its not all the time though. weird.
Old Aug 24, 2006 | 10:57 PM
JKDZ28's Avatar
Well...at least now - I feel better. Sure am glad I'm not alone.
Did you ever find out what yours problem was?
If/when I figure out what the problem is, I'm going to post the solution on here for others with similar problems to learn of the fix.
Old Aug 25, 2006 | 07:25 AM
kenkaru's Avatar
Looks like it's normal. I say you just ignore it and turn up the radio.
j/k
Old May 9, 2010 | 05:21 PM
Tom565's Avatar
Anyone figure out what causes this yet? My car does the same thing. Really weird.
Old Aug 23, 2012 | 07:58 PM
Tom565's Avatar
The car is still doing it, anyone found a fix yet? I already replaced the brake switch and they still come on when I shift or when the tires are spinning.
