Koni SA owners inside
HOWEVER, I am running Hotchkis springs, 1LE sway bars, etc., so your setup may be different from mine.
-Mike
4 clicks from firm in front, full soft in rear.
The only tool you need to adjust them is an allen wrench, you can buy the specific size needed for under $5.00. That and a jack to raise the front end up so you can get to the adjustment. The rears adjust inside the car (if you have 4th gen rears) with a dial, so no tools needed.
It really depends on your setup (springs,tires, swaybars etc.) and you're driving style and feel.
That might help a little. The adjustment window on the front shocks is on the top (closest to the fender well). The adjuster on the rears (for the 4th gen, which is what I have) is on the very top, where it bolts to the body.
-Mike
