CTS-V brakes, something different
Old Mar 16, 2007 | 06:20 AM
  #81
w02ramair's Avatar
I ask because you might be able to find a BMW two piece that might work. I know the wheels are offset a bit different and the bolt pattern is so close that a dremel would take care of anything not sliding right on.
M3 Specs
Old Mar 16, 2007 | 06:25 AM
  #82
w02ramair's Avatar
Z51 rotor just for clarification...
340x32mm (13.3" x 1.2")
Old Mar 16, 2007 | 06:27 AM
  #83
w02ramair's Avatar
ok i found this
you need the rotor to have a minimum of 27mm from hub to surface of the rotor..
but that doesn't give me much info on how deep the rotor hat has to be.
Old Mar 16, 2007 | 06:29 AM
  #84
w02ramair's Avatar
Z06 Rotors...C6 style
Size: 355x32mm (13.9" x 1.2")
Old Mar 16, 2007 | 06:34 AM
  #85
w02ramair's Avatar
Audi TT
Size: 312x25mm (12.2" x 0.9")
Old Mar 16, 2007 | 06:57 AM
  #86
w02ramair's Avatar
well crap..those measurments don't help me none they werent for what I thought they were for...
but here is an idea...how hard would it be to get a hat made?
Since you are making the adapters..
200 bucks buys you a pair of rotor rings
Old Mar 16, 2007 | 07:52 AM
  #87
JasonWW's Avatar
Originally Posted by w02ramair
ok i found this
I was looking at some caliper clearance templates between the C5 caliper and the C6 Z06 caliper and I also believe the stock vette rotor has 16mm of offset as previously mentioned. The stock caliper extends 0.8" from the outside surface of the mounting hub. The fatter 6 piston caliper extends 1.7" out. So that's about 1 extra inch or 25mm.
I don't know how thick the CTS-V caliper is, but I assume it's pretty close.
I was also able to look at a C5 vette with some rims that resembled the base C6 rims. There was almost 1 inch already there between the caliper and the spokes. I'm sure that a small spacer of 5mm would make room for sure. This was an 18x8.5 rim with a 56mm offset. With a wider rim of the same offset there should be plenty of room for the CTS-V caliper to fit. This is with all stock C5 and C6 Z06 rotors mind you as they both have the same offset.
So on one hand the vette rotors will work as long as you have the right rims. For you guys who already have nice rims, but lack any extra clearance (lets say you current rims are almost touching your C5 calipers) you would need to push the rotor back an extra 0.9". So if the stock C5 rotors already has a 16mm offset then you would need a new rotor with a 40mm or so offset.
If I had the deminsions of the C6 Z06 caliper and the CTS-V caliper I could compare them and give a more exact number, but for right now I'm assuming they both are similar in width.
Does all that make sense? So 40mm (1.6") from the rim contact area on the hub to the surface of the friction disc. This is so deep that it might not even fit. Eventually the rotor will hit something. I don't know what the limit is though. EDIT: I FOUND THE LIMIT. THE MOST OFFSET WE CAN RUN IS ABOUT 30mm.
If you have either the LS1 or C5 calipers right now and almost no spoke clearance you can look and see how far back the rotor can move in before it hits something. You would need an additional 25mm (1") of space. If you do have spoke clearance, measure it in mm. and subtract that number from 25. This new number will tell you the MINIMUM extra backspacing your new rotor will need just to barely clear the spokes. So you may want to add a few extra mm just to make sure it will clear.
This section above has been reworked.
Assuming we can find a rotor with a 40mm offset and assuming that the rotor doesn't hit something first (like the spindle) we can have a single rotor that would work for everybody. EDIT, 30mm IS THE LIMIT.
For those of you who currently have a nice gap from the spokes to the C5 calipers you wouldn't need the 40mm offset rotor as you could use a shallower rotor. If you already have a 1" gap then you can use the vette rotor. So the minimal rotor offset is going to vary from person to person based on how much spoke clearance you currently have.
Hopefully my logic is correct. Let me know if it's not or if you need me to further explain it.
Old Mar 16, 2007 | 08:19 AM
  #88
w02ramair's Avatar
If you have the 13" rotors right now you can look and see how far back the rotor can move in before it hits something. You would need an additional 40mm (1.6") of space. If you have the 12" rotor right now, you need to measure how far back it can go and you would need an extra 36mm (1.45") clearance.
I believe the Spindle is what limits your ability to have a deep dish rotor hat. Wouldn't this also change the positioning of the caliper to center itself ont he rotor?
Old Mar 16, 2007 | 08:21 AM
  #89
JasonWW's Avatar
That's the whole point, to move the caliper back so the rims will clear.
Old Mar 16, 2007 | 08:33 AM
  #90
JasonWW's Avatar
Originally Posted by fast377
I got bored tonight at work and went through the brembo brake rotor catalog (stock replacement) and looked at all the dimensions and stuff. I don't know the bolt pattern on these, all I know is that they are 5 lug and what they fit. There are only 5 part numbers that come close measurement wise...here they are (height listed is measured from outside of hat to rear side of friction surface):
2004 Audi A8: diameter=360mm, thickness=31mm, height=60
1992-95 Ferrari 512: diameter=315, thickness=30, height=61.7
1993-98 Ferrari 456: d=315, th=30, h=61.7
1996-98 Ferrari 550 Maranello: d=330, th=30, h=60.7
2003-04 Mercedes E55 AMG, SL55 AMG, SL600: d=360, th=34, h=64.5
Those are the closest I could find out of EVERY car that had dimensions relative to what was discussed earlier in this thread.
Based on these height measurements, none come close to the 72mm we need. EDIT: WE NEED ABOUT A 60mm HEIGHT, SO THESE ARE ABOUT RIGHT. So as far as stock rotors go, not everyone would be able to use these. If we all had at least 10mm gap from the spoke to caliper on our current rims, these would all work. Or, if your spokes have no gap and you think the rims would look OK if you spaced them out at least 10mm and used longer studs then all these rotors should work (at least height wise). What would have to be done is redrill new lug holes and then if the center bore is larger than the stock 70mm or so then we would need rings to get the rotor centered properly. If the bore is smaller, we can have it rebored larger to fit over the hubs. Then we would be set. This is based on the room we have to move the rotor back, though. Someone really needs to get in there and measure how far back we can go.
Does anyone know the which of these rotors would be the most cost effective?
Those 360mm ones are 14.4". Whew!, might need a 19" wheel for those. That's cool with me.
Old Mar 16, 2007 | 08:38 AM
  #91
JasonWW's Avatar
Here is a thread showing what type of caliper brackets we would need.
https://ls1tech.com/forums/cadillac-cts-v-2004-2007-gen-i/504354-need-pics-caliper-mounting-locations.html
Old Mar 16, 2007 | 09:05 AM
  #92
w02ramair's Avatar
Right...so if you keep pushing the rotor back then the caliper is gonna have to move back too which means those modified mounts would have to be modified again. I think all that would be required is the bosses that the studs go through would have to be thickened up howerver much mm you want to move the rotor and caliper back.
Old Mar 16, 2007 | 09:11 AM
  #93
JasonWW's Avatar
Your getting the order mixed up. You can't make the mounts until you pick the rotor you want to use. First you get the rotor, then you make the mounts to fit the caliper on it. Some folks might want to run a 340mm diameter, others a 355 diameter. So the brackets as a whole have to be made based on the rotor dimensions.
I am going to use the C6 Z06 rotor as they are 355mm, require no redrilling or added rings (they slip right on) and only cost about $90.
I have a feeling those Audi A8, Ferrari and Mercedes rotors are going to cost an arm and a leg. Also, custom hats for the generic rotor rings is going to be quite expensive as well.
I don't know what your talking about here.
Old Mar 16, 2007 | 09:17 AM
  #94
BaddillaK's Avatar
i think he was talking about basically using bosses as a spacer to move the caliper mounting bracket farther away form the rotor, if you got more of an offset on the rotor, instead of having to get a new caliper bracket made
Old Mar 16, 2007 | 09:21 AM
  #95
JasonWW's Avatar
If we can get those rings for about $100 ea. (as mentioned above) then that would be fairly equivalent to the Z06 rotor prices. It's just the hat's that will cost the extra money. Once they are bought, the cost to change the rings would be the same as the vette rotors. The only big advanteges to the 2 piece rotors would be the custom offset and the weight reduction, at the expense of price.
There is also another issue involving the internal vanes on the Z06 rotors. They only make on rotor and it has curved vanes for cooling. This is fine on one side of the car, but the other side has the rotor turning the opposite direction. Many think this is going to cuase a cooling problem. With the replacable rings, the cooling fins should all be optimized. This minor cooling issue is no big deal for me.
Old Mar 16, 2007 | 09:22 AM
  #96
w02ramair's Avatar
Old Mar 16, 2007 | 09:27 AM
  #97
JasonWW's Avatar
That also would not work. If one person wants to use a slightly different diameter rotor, the bosses could not compensate for that. If we could agree on a single diameter and found say 2 or 3 hats that would work with different offsets, then you could choose the hat that would best work with your specific rims. In this case, we could make a single bracket designed for the tallest hat and if you use a shorter hat, we can add slip on spacers to move the caliper to the right position. So each hat offset would have a matching set of spacers to use. That would work for the 2 piece rotors, but not any of the OEM replacement rotors.
Old Mar 16, 2007 | 09:29 AM
  #98
JasonWW's Avatar
That is correct. You can move it in until you reach some kind of limit.
Old Mar 16, 2007 | 09:46 AM
  #99
JasonWW's Avatar
NOTE, I reworked the numbers I used from post #87 to read like this:
Old Mar 16, 2007 | 09:54 AM
  #100
JasonWW's Avatar
For instance, here are some extremes.
If you currently have 25mm of spoke clearance with the 13" C5 rotor you can swap over to the 355mm Z06 rotor. This switch will not change the rotor offset because they are the same. This should just clear the new caliper.
If you have 2mm clearance and are using the 13" rotor and swap to the vette 355mm one, then you would need to either add a 1" adapter to push the rims out (that would probably look like crap) or else switch to a different rotor with a 40mm backspace or 72mm height based on a rotor surface thickness of 32mm.
Then there are variations in the middle.
Lets say you have the 13" rotors and have about 15mm spoke clearance and you don't want to push your rims out any further than absolutely neccesary. You can subtract that 15 from the 25 and you get 10mm. So lets say 12mm just to be on the safe side. So 16+12=28mm. So you need a rotor with 28mm backspace or 60mm overall height.
