Short Torque arm or Stock length for AutoX/RR?
I'm in need of an adjustable torque arm to fix my pinion angle. I'm wondering if I should get one that mounts to the stock location on the back fo the tranny, or one that mounts in the stock tunnel brace location... I don't know if changing this angle will have any affect on my handling, I'm hoping mitch or trackbird or anyone else with some real knowledge will chime in here...
Thanks guys!
Thanks guys!
Blane I was just looking into this and searching around FBRRAX. (Those guys are regulars there). It seems thier concencious is that the short arms are great for drags due to maximum anti-squat but not good road race because they have the opposite effect under brakeing (lift). The short arms will at least reduce rear braking effectivness and could cause wheel hop under brakeing. Long arms for RR/AX.
Vernon
Vernon
Vernon
Vernon
Moderator
It's an artifact of the link geometry. The short torque arm
magnifies all torque reactions. Good for launch as it does
the downforce; bad for braking as it makes upforce there.
Hard core 3-link suspensions sometimes use separate arms
for braking and acceleration torque snubbing. Decouple the
two reactions. But that's not something you're going to find
mail order, I reckon.
Stock length is going to be more balanced and less trouble,
which is why it is where it is (forward even more would be
more neutral, but there is that inconvenient powertrain).
Vernon
Vernon
