Need help with pissing contest.
I know its retarded to argue with stupid people but he has pushed every one of my buttons and I want to make him look like a complete tool in class on Wednesday. So any of you with exp between the 3rd and 4th gen and why which is better at handling let me know. Even if I am wrong (which I doubt) I'll go to class and admit it.
thanks,
-Nate-
**no offense to all third gen owners lol**
But pull up some Road and Track reviews from the late 80's early 90's on the GTA or Z28 and then pull up some on the 98 to 02's hell even the LT1's that would be fine to. As far as quarter mile....you would so beat his ***. Thats not even worth argueing about.Your talkin the difference between a 15 second car and a 13 second car. As far as autocrossing the difference probably isnt that much different but I am sure the newer car would hand the third gen its *** in that department too based on tires, wheels, and shocks and springs. To me when I get in a third gen it feels like it is to soft but in some newer 4th gens i have gotten in they exibited body roll and understeer too. So I am not really sure on that one.
In a 98+ 4th gen, the motor is 100lbs lighter, making the balance even better
In 4th gens, it has a true double A-Arm with a coilover shock, stabilizing the front end geometry.
4th gens came standard with 50 more cubes.
That being said .... a 3rd gen can be made to handle quite well.
My '96 Z-28, which I traded the Firebird for, also handles well. I went a similar route with the Z, lowering springs, and wider wheels (16x9.5).
made more torque..are you crazy?
the stock ws6 sway bars on my trans Am i believe were 32mm..i dont think the ws6 or GTA third gens had anything bigger than that. Plus the brakes on 3'rd gens is a hellava lot smaller.
Unless you got the 1LE package. Now thats a whole nother ball game.
There are too many differences in cars and parts to compare. I've competed in and owned both. A stock late 80's early 90's Z28/WS6 is a better handling car in my eyes. Bearing in mind "handling" is a broad brush word. GM mucked up the suspension settings of most 4th gen cars stock. The SS's are better, and better still if they have the Level 1 or Ultra Suspensions. Those options get you very similar handling.
FWIW, 36mm front, 24mm rear bars were common in non-1LE 3rd gens.
Bottom line is, and I think the results from National Solo events prove, that the cars can be comparable, but each has it's strength and weaknesses vs. the other.
I know this thread is kinda old. But I gotta stick up for the 3rd gens. Yes...they are slower than a 4thgen. Unless you have 4th gen power under the hood
Now where do you stand? I say you will handle better in a 3rd gen. Ive been to a couple auto-x events with my car when it was a 305 TPI. Yes the 1/4 was a joke. However...coming out of corners I could mash the gas, get full power, and not have to worry about smoking the rear tires off. I was at an event in 1998 with a buddy that had a 99WS6 bird. And I pretty much whooped up on him in the twisties. My feelings towards the 4th gens were always that they were alittle soft. You get into my 87 TA, and it rides kinda crappy.... but so do race cars. The car always outhandled its own powerband. Sway bars were 36/24. And I had the WS6 suspension package.
Like mentioned above... the rear suspension is identical. Also, the statment about the engine sitting further back isnt exactly true, because the drivetrain length is the same. Rear end is basically the same....drivetrain length is the same...so it cant be sitting further back really. The cowls on 4th gens extend further forward. More rake on the wind screen. Same amount of room in front of the motor. The only real difference is the coil overs and double a-arms in the front.
Brakes were sub par, yes... However there are some 3rd gens running around with 4 wheel disc from the factory. Those stopped good enough for most spirited driving.
I guess my point is, there shouldnt be an agument between generations. Keep that argument between the f-bodys and the mustangs. Thats why I built my car. 87 styling and handling, with 4th gen power and economy. Why not mold the two together? Best of both worlds in my opinion. I say with all the 4th gens being wrecked these days, that the 3rd gen guys should take advantage of this and for the LS1 swap. Take a great handling car, triple the power (in some cases), and lighten the front end... whats not to like in that combo?
That kid is a choad for not sticking up for his car by racing it against yours. Especially because you offered to take him to legal places to prove it. Ide be jumping all over that if I were him
J.
Out of the box my 89 seemed to handle better than the 2001. My 89 ended up only having a sub frame connectors and STB and poly bushing and poly end links. It handle very weel for those mods.
my 2001 handled like crap out of the box. Once I added STB, SFC, Koni's, welded the rear control arms it handled alot better.
Like Sam said, they are alot of pros and cons to each year and both are very formidable cars.
and FYI to whoever said WHAT on the TPI torque amounts...The 350 TPI cars did make more torque than the LT1 and LS1 cars but gave up alot of hp to only the LS1. The LT1 in its 4th gen platform only made 10 more hp in the base model over the L98 motor.
BTW - Back as far as 1985 the IROC generated .92-.95 lateral G in every magazine test.
And the guy most likely declined a race due to the overwhelming advantage that your car has. Even if his car did handle better, your power, gearing, and braking should easily overcome that. And if you put up a better time, why should you entertain the idea that his car handles better...
BOSS APPROVED!
