UMI LCA relocation bracket help ASAP
and this is a pic from the UMI site, notice the bracket is different. is my car wierd or something?
Cut the bracket as the two pictures from our site show. It is very easy to do and will not hurt the bracket or cause you any problems. Then you just use the top bolt to hold it in place.
I can't access our installation instructions since I am home for the day.. but maybe this was left out? I will double check them and add it if it was.
But again, just cut the bracket in half or right where the factory weld is and they will got right on. Use a hack saw, cut off wheel or recip saw.
Any more help needed just reply and I will try to check back shortly.
Thank you!
Ryan
Thanks Jim, yea it is mentioned in the weld in instructions. We must have left it out on the bolt ins for some reason.
Thank you!
Ryan
+changed shocks). I think you could get away with not cutting the bracket but, bending it out of the way on the inside but it would look weird. I just took a cutoff wheel in there and carefully buzzed it off.
Thanks,
Ryan
Does it handle better.
Thanks
car doesn't handle any better on the street, but thats not what these were designed for. im goin to the track this weekend so ill see how they feel on a good launch
