anyone use coil over springs..look inside
I was thinking about getting these so I can adjust the height of the ride, has anyone bought these and what do you think?
http://www.ws6project.com/user_stor/catalog/product_info.php?products_id=839{6}413&osCsid=dce9 16d358f3c4aaf110d45447ff6a13
also any help with front and rear spring rates I should get would be helpful.
Its a street car so I want good street manners that handles well, take it to the track on occassion. I have the bilstein shocks from the slp level 1 kit...
Thanks
Thanks
I am running those Ground control perches(replaced the rear portion of the SLP level one system). Mainly due to the fact I am 400 pounds over on the rear axle. Went w/recommendations from Strano....... 10" 175# linear springs over the Eibach 15" progressive lowering springs. Swapped out the Bilstein HD shocks for Koni 4th Gen SA's. Returned my ride height to normal, and I also now have dampening adjustments.
It was something I HAD to do, and ride is acceptable! Definitely firmer.
