Energy Suspension= Shotty
![Thumbs down](https://ls1tech.com/forums/images/icons/icon13.gif)
I can believe the quality of their products. I ordered their stock 19mm setup for the rear and the dam endlinks are too short on top of the factory nuts almost going thru the bracket holes, they can even provide you the right spacers. I got a bigger swaybar for the front and the dam sway bar brackets wholes were too small for factory bolts, so i had to take and have them dremel out. On the rear i had to go to the local parts store and buy another set of endlinks that had longer bolts.
I would find another suspension place if i was too do it again
hi google energy suspension and look for dealers,i bought front sway bar bushings and end links for my 02 hawk. they offer all different sizes and lenghts i got true ,bolt in replacements .( i also have a 35 mm sway bar ) 1'3/8 fit perfect billyb.
