What's the best flat washer?
Old 11-07-2006, 08:57 AM
mitchntx's Avatar
How about a washer dyno? Post your numbers!
I torqued a nut/washer to 225 the other day. Beat that!
Old 11-07-2006, 09:15 AM
trackbird's Avatar
I have a 22" Snap On breaker bar. I can only measure torque to 250 ft lbs, but my butt dyno say this is much more than 250 ft lbs....
It's probably 450 or more....
Old 11-07-2006, 10:01 AM
Fulton 1's Avatar
blah! washer dynoes are worthless. See how those washers do at the track.
Old 11-07-2006, 10:30 AM
trackbird's Avatar
Yea, but my washers never hook up and the times are slower than they should be.
Old 11-07-2006, 10:34 AM
MrDude_1's Avatar
what you need are adjustible washers so that you can set the washer angle to -12*.....
Old 11-07-2006, 12:01 PM
chupr0kabra's Avatar
I don't know, I usually washer my car about once a year.....
Dude! You should washer it more often and use Zaino, because Zaino will cut a tenth off your ET!
-Mike
Old 11-07-2006, 12:08 PM
trackbird's Avatar
-Mike
If I washer it at all, I use Meguires.....
Old 11-07-2006, 12:22 PM
mitchntx's Avatar
Good info.
Mods ... we need this stickied!
Old 11-07-2006, 12:38 PM
MrDude_1's Avatar
i just washered my car, but it rained. do i need to re-washer it, or will the old washer still work after getting wet?
Old 11-07-2006, 01:18 PM
Fulton 1's Avatar
I found this washer on eBay. Do you guys think it'll fit? This is my daily driver if that matters.
http://cgi.ebay.com/SpeedQueen-Comme...QQcmdZViewItem
Old 11-07-2006, 05:27 PM
trackbird's Avatar
That's the coin operated type. Of course you can always just put washers in it instead of change.
Old 11-07-2006, 07:04 PM
  #32
DONAIMIAN's Avatar
We just covered this last week, please use the search button.....
Damn newbs.
Old 11-07-2006, 09:29 PM
  #33
trackbird's Avatar
Damn newbs.
I couldn't find anything on carbon fiber washers in the search.....maybe it's broken.....
Old 11-08-2006, 04:52 AM
  #34
mitchntx's Avatar
So do I put the poly side up or the rod end side up?
Also, when I tighten down the hex head, one of the corners of the hex covers up the adjustment screw. What special tool does it take to fix this?
Anyone else washer-bind on hard cornering?
Old 11-08-2006, 08:23 AM
  #35
Fulton 1's Avatar
Just grind down the corners on the hex to get clearance.
Hey, does anybody know if I can use shorter bolts with the stock washers? I just got $100 for my birthday and want to buy some shorter bolts, but don't have the $$ to do washers as well.
Old 11-08-2006, 09:14 AM
  #36
mitchntx's Avatar
You mean lowering bolts, right? Only if you revalve your washers. Otherwise you will die a horrible death.
But won't that cause wrench hop?
Old 11-08-2006, 09:16 AM
  #37
FirebirdWS62K1's Avatar
For my WS6 I stick with 12 bolt washers. On the 92 I like 9" washers. I do get harassed by the Ford guys that there washers are stronger but us GM guys stand by our washers. I liked it back in the 70's when washers were washers, ya know.
Oh and a little about bolts. If you NOS the bolts they are faster and stronger. Oh and don't ever use anything but a 8-32 Torx 15 bolt , bigger is a waste of money and weight.
Old 11-08-2006, 09:57 AM
  #38
v7guy's Avatar
I like the titanium washers but hear there are problems with them becoming brittle if they get too warm, how are you guys cooling these? Can I still chrome them?
Keep in mind my parents have to approve since I'm 17
Old 11-08-2006, 10:04 AM
  #39
Fulton 1's Avatar
Right, I meant lowering bolts. Yeah, I've done a lot of research over the last week or so and it sounds like the valving on the stock washers sucks. Using them with the stiffer lowering bolts will probably cause the OEM washers to break. Crap. I think I will do it anyway, though, and see what happens. I'll post up pics once I get all the parts.
Installing drag bags on your wrenches will help. These should improve your 60ft-lb numbers too.
Old 11-08-2006, 11:48 AM
  #40
trackbird's Avatar
They will probably be stuck in the mounts and you'll have to replace them.
I need to get my washers drilled for safety wire so they don't fall off.
Quick Reply: What's the best flat washer?
