subframe connectors
they are welded in and my question is, do you think i can grinnd off the welds and put in a different set of sfc, and should i bother even doing it.
should i bother going to boxed kind, i really like the 3 point kind, but then ill have to go back to a y-pipe setup.
next year when i have the car going, i plan to have a much more "agressive" setup, and plan on some hard launches, and i want everything to be right before i twist my turd in half.
give me some opinions on what i should do,
thanks
I am not trying to be rude at all, but you are not flexing them, don't worry. I actually don't know IF you were how you could tell? But I insure you they are not.
Mitchntx on this board is running those SFC's on his CMC car, maybe he can chime and in as well that he is having no issues with them. We also run them on many quick drag cars.
Again, I am not trying to be rude but I think it is in your head
Thanks,
Ryan
Mitchntx on this board is running those SFC's on his CMC car, maybe he can chime and in as well that his they are not flexing for him. We also run them on many quick drag cars.
Thanks,
Ryan
but this is why i posted this up, and wanted to get other peoples opinions before i started grinding welds away and bought something else from you guys
i think i should have bought boxed in the first place because it is much more rigid, but i love how the tubular ones just tuck right in place, its looks really clean, because my buddy with a camaro has some sort of boxed ones and you can see them hang down a little
I am not sure what else to say. If you feel you need to spend more money and remove them for a "stronger" set-up then got for it. But I think it would be very silly and a waste of money for no gain. That is my honest opinion.
Hope that helps some,
Ryan
if u dont have a lift, i used front ramps and rear jack stands under the rear as far out as i could get them, worked fine, but i used bolts on's which are more forgiving.
