Bump stops on shocks
Old Nov 9, 2006 | 09:31 AM
rocket22's Avatar
Default Bump stops on shocks
I seen some where on here where some but a bump stop on the shock after cutting the factory bump stop off,where can I get them.
Old Nov 9, 2006 | 10:41 AM
trackbird's Avatar
Koni makes them and I did that for a while. In my case, I damaged a set of Koni DA's due to bottoming them out. If you have the travel with your shocks to use that stop without damaging the shock, you can get them from a Koni dealer (sorry, I don't have the part numbers handy).
Old Nov 9, 2006 | 10:50 AM
Sam Strano's Avatar
LS1TECH Sponsor
:shakes head:
I sell them, but you'd be far better off finding a way to install the OEM type back on the car.
__________________
Old Nov 9, 2006 | 11:06 AM
01bird58's Avatar
Is there a way of shaving the stock ones down to make room for a 315mm tire? Or is the only solution to install spacers?
Old Nov 9, 2006 | 11:23 AM
Sam Strano's Avatar
LS1TECH Sponsor
I run 11's and 315's with full size stock bumpstops. If you drag them with the tires or wheels, the offset is wrong. Don't screw up the suspension to "cure" your wheel fitment issues. And monkeying with the stops will screw something up. Even cutting them in half makes them less effective, and they are a integral part of the suspension.
__________________
Old Nov 9, 2006 | 05:24 PM
rocket22's Avatar
Thanks for all the response.
Old Nov 9, 2006 | 05:40 PM
SmokeySS's Avatar
Say Sam, what, if any, modifications did YOU have to do to get 315s to not rub?
Old Nov 10, 2006 | 01:32 AM
BirdmanLS1's Avatar
I have heard that the Nitto DR's dont require any modifications to fit, but other DR's have had to pound the wheel well and what not. An adjustable PHB is pretty much mandatory too i think... i may be wrong tho.
Old Nov 10, 2006 | 12:28 PM
Sam Strano's Avatar
LS1TECH Sponsor
Rolled fenders, carefully picking wheel offset, and a REAL PHB.... And they do rub a touch from time to time, but also under over 1g of cornering. 315's are BIG, and some are bigger than others. Pick a narrower one and it'll help a lot.
__________________
Old Nov 10, 2006 | 03:56 PM
SmokeySS's Avatar
Is the UMI double adj. a real phb? Heh.
Old Nov 10, 2006 | 04:00 PM
'Trust''s Avatar
I assume by real PHB you mean one that isn't factory and is adj.? What are the sizes/offsets/backspacing on your wheels?
Old Nov 10, 2006 | 04:01 PM
Sam Strano's Avatar
LS1TECH Sponsor
I'm not sure I follow.... Meaning UMI's biggest PHB is not? For something relatively easy to make, there ar a lot of junk ones out there. UMI isn't aluminum (good). Used high-quality rod-ends (some don't), the welds are very strong (and battle tested by yours truly) which isn't always the case on chrome-moly steel as many folks weld it too fast and it becomes brittle, they don't.
__________________
Old Nov 10, 2006 | 04:06 PM
Sam Strano's Avatar
LS1TECH Sponsor
I mean an adjustable bar with rod-ends at both ends..... poly bushed PHB's are not IMO "real" PHB's as bushings still deflect.
As for wheel offset and such. Well, I can't give all the secrets away randomly on the web, but also not all cars are exactly the same (and again the actual section widths vary).
__________________
Old Nov 10, 2006 | 05:45 PM
UMI Performance's Avatar
Thanks Sam, I also have a double adjustable PHB bar here that survived a 50 mph crash into a curb, craking the axles and destroying the rear end, I won't mention the members car unless they want too. The PHB did bend like a bananna but the welds show no cracks and held up fine.. you want a part to bend before a weld breaks.. it shows a good weld.
I am not sure I follow either SmokeySS?
Old Nov 10, 2006 | 06:54 PM
SmokeySS's Avatar
I just bought and received your DA chrome moly panhard bar through Stranoparts and I'm double checking that I got a "REAL" one. It was half a joke.
Old Nov 10, 2006 | 07:57 PM
ahhh ok, no biggie and good to hear
Guess we took it the wrong way... no worries!
Thanks for the order
Ryan
Old Nov 13, 2006 | 11:48 AM
Sam Strano's Avatar
LS1TECH Sponsor
Oh, I get it... just mis-understood the tone (gotta love e-mail).
BTW, the PHB Ryan was referring to, came off of *MY* car. It was wrecked this summer, about 2 months before Nationals (not by me) and we pulled a lot of strings to get it fixed in time for Nationals (thank god, because it went *quite* well).
The damage was big, about $8k worth but the welds on that PHB held up great, I actually gave it back to him on purpose so he would know how it held up.
__________________
