whats the difference in adj. panhard bars
-J
-J
http://www.umiperformance.com/2022.aspx
The on-car adjustable, # 2022 is our most popular. It allows easy on-car adjustments and is some what inexpensive.
Hope that helps!
Ryan
And the big double rod-ended PHB is not hard to adjust, but you do have to leave the jam-nuts loose when you put it on, then you can just adjust the bar right on the car and when you get it where you need it, pull the two bolts, tighten the jam nuts and put the PHB back in. Not exactly hard and only takes about 10 minutes more at most. A small price to pay IMHO.
I tried a PHB years ago that was poly/poly at both ends. While it helped the feel a bit because the bushings are stiffer, the tires rubbed just as much as with a stock bar. With the installation of a rod-ended bar (both ends) the rubbing stopped almost completely. Of course tires are not all the same width and there are other variables. But polyurethane is still a flexible substance, and the greater the load on the PHB, the more you will see the difference between poly and rod-ends and less of a difference between rubber and poly.
