QA1 settings in rear shocks to hook on street
If i didn't have so many neighbors around I'd play with different settings to see what works but thought I'd ask here what works.
Should I set it softer to hook like at a 2-3 or stiffer like a 6-7?
I know I won't be able to hook perfectly it would be nice to see if I can plant a little harder doing light to light races.
Anyone care to share?
If you want to hook you will want to set them stiffer like 6 or so, this will allow when the rear goes down when you hit the gas, it buries the tires into the pavement and will hook alot better.
