Koni question
Old Nov 22, 2006 | 06:43 PM
torlak_t's Avatar
Default Koni question
what do u guys think about koni 4/4 and 4/3. quite expensive though. will i get really good performance and any other ideas for same handling as koni shocks.
Old Nov 22, 2006 | 07:55 PM
BlackHawk T/A's Avatar
Not to totally hi-jack, but on the topic - an online store lists a:
Koni Sport Yellow single adjustable Mono-Tube rear shock 1993-2002 each
And
Koni Sport Yellow single adjustable rear shock 1993-2002 each
Can anyone tell me what the difference is and why do I never hear about it on here? There is a $50 difference.
This wouldn't be the on-car adjustable you are paying for is it? They certainly don't explain any difference between the two, both have the same descriptions.
To answer your question, from what I have read Konis are the best street and corner carving shock for your dollar. It is what I will be running on my car eventually.
Old Nov 22, 2006 | 09:36 PM
01 Red WS6's Avatar
I have the 4/4s and I love them. Great shocks and will make a world of difference compaired to the crappy stock shocks. They are well worth the money
Old Nov 22, 2006 | 09:38 PM
LvDemKings's Avatar
I'll second that.
Old Nov 23, 2006 | 05:51 AM
torlak_t's Avatar
what springs are using with koni?
Old Nov 23, 2006 | 08:31 AM
J. Brown's Avatar
I'm using factory springs set to the lower perch on the front and the hose mod on the rear springs..........this equates to a 3/4" drop front and back but maintains factory ride.
Old Nov 23, 2006 | 09:41 AM
01 Red WS6's Avatar
I'm using BMR springs
Old Dec 5, 2006 | 09:25 AM
Second_Infinity's Avatar
Do you scrape much?
Old Dec 5, 2006 | 09:29 AM
torlak_t's Avatar
im planning of buying just shocks now, otherwise, i might need adjustable panhard bar as well. do you guys think konis will give good performance with stock springs?
Old Dec 5, 2006 | 10:50 AM
LvDemKings's Avatar
Absolutely. Their adjustability will be what controls their performance, soft or firm.
Old Dec 5, 2006 | 10:40 PM
01 Red WS6's Avatar
Originally Posted by Second_Infinity
Do you scrape much?
Nope not really. I can probably count on 1 hand the number times I've scrapped
Old Dec 6, 2006 | 11:59 AM
Goldstreak65's Avatar
I second that motion, please what the hell is the difference between the 4/4 and 4/3.
Old Dec 6, 2006 | 12:01 PM
02SS#406's Avatar
4th gen. rears are easier to adjust (on the car).They also have more adjustability. 3rd gens need to be un-bolted from the car to adjust.
Old Dec 6, 2006 | 12:31 PM
gun5l1ng3r's Avatar
What would be a good initial setting on the rear 3rd gen's for a canyon carver?
Old Dec 6, 2006 | 12:36 PM
Sam Strano's Avatar
LS1TECH Sponsor
Any specifics I tend to not just give out too freely. Too often folks are willing to take the knowledge I have, and give away for free to customers, and run and buy parts elsewhere. So not giving away the farm is something I'm kind of forced to do. Service includes that kind of information, and if you can get the things milk for free... Well folks become all about the price then.
And there are other details that make the two rear shocks different. The adjusters are quite different in the amount of change one is able to cause. It's not just one is easier to adjust.
__________________
Old Dec 6, 2006 | 06:39 PM
dgmiller's Avatar
I have single adjustable Konis on both the front and thr rear of my 99 SS and they made a huge difference in the handling. Of all the things I have done to the suspension they made the biggest improvement. The 35 mm front bar made the next biggest improvement. For autoX I run the fronts and three below full firm and the rears at one above full soft. For the street I run them all at full soft. I get very little nose dive on hard braking and in slaloms the car does not start to rock as it did with the stock Decarbons. I am running on the lower spring perch in the front and I have done the heater hose mod in the rear to lower the car 1/2 to 3/4 inch.
Old Dec 6, 2006 | 07:22 PM
Sam I spoke to you the other day about about my 2000 Camaro v6 convertible with the 32 front sb. I wanted to the use some v8 springs I have and buy some konis from you. We both thought the the Bilstein bts kit was a gimmic. As soon as I have the money for the konis you'll have the money. Thanks for the good imput hope you remember me I'm coming to check out the autocross in richmond where you said you would be racing, It will be my first time to an autox some I'm looking forward to it.
Old Dec 6, 2006 | 07:51 PM
rocket22's Avatar
You run them in the top or bottom perch setting
Old Dec 6, 2006 | 10:43 PM
01 Red WS6's Avatar
Top perch. The bottom perch is for stock springs. If you tried running the bottom perch with a lowering spring I think it would be too low to drive with
Old Jan 15, 2007 | 06:03 PM
torlak_t's Avatar
can you post the pictures of your rides with konis and stock springs?
thanks
