Question for UMI
These were on the passenger side, on the panhard bar end and on the LCA.
The bushing material crumbles, every bushing is at least split front and rear even the ones that look ok.
Any ideas?
Any guesses on bushing brand and part #?
I don't think they would harden and fail within 18 months, and they shouldn't bind, they have steel spacers that prevent over tightening them plus they did move free with one end installed.
I have 11 year old generic poly bushings on a more powerful car and they look like the day they were installed.
These properties allow polyurethane to be used in some of the harshest of environments with minimal deterioration."
From here.
Just my thoughts.
I'm looking for input about why these failed, info on how to get new bushings, advice on how to keep the new ones from failing, I think it would be easier to go through UMI for the sizes, energy suspension has a standard size for aftermarket f-body lca's and they are bigger than what I have. I only posted the name because I seen a recent post from UMI here and was looking for input from them. Never did I say anything negative about anyone.
Just my thoughts.
Thanks Trackbird and Byunspeed
Actually those bushings aren't Energy Suspension, when we first started we were using a different brand and had switched to Energy Suspension shortly down the road, that was a couple years ago. I have never seen a set do that though and that amazes me.. I have no idea what would have caused that and I sorry to see that.
I will gladly send you a new set of bushings to replace them. I have a few sets of those older control arm bushings here in stock. However I need to look around some, I don't think I have anymore of those older panhard bushings... The new bushings we used are much larger and will not work.
I will look around and send you a PM on Tuesday, I will be out of the office until then. We will get you fixed up somehow
Thanks and hope everyone had a great Holiday,
Ryan
I guess the place I got these from had them sitting around a while if they are an older design.
EDIT# I'd be happy to buy them, or if you have a part# I've looked at online catalogs and can't seem to find the right size.
Ryan
I almost just ordered a set to avoid the hassle of searching for bushings, but I went out and bought a set of used stock lca's and phb so theres no hurry now.
I'm not necessarily looking for a deal or free parts, if theres a better design out there I'd rather buy the whole set of lca's at regular cost. Or do you think these bars with the smaller bushings will work ok?
