need suspension/bumpstop help
Old Dec 4, 2006 | 08:42 AM
brienjustin's Avatar
Default need suspension/bumpstop help
I have the Eibach sportline springs all the way around, Bilstein shocks all the way around, adjustable lower control arms, and adjustable panhard bar. I got the springs off ebay used for about 2000 miles (so he said), everything else I got new. The passanger rear hits the bumpstop all the time and sits about 1 1/2" lower than the drivers side rear. I do not know what to do. I have heard of springs sagging. Should I get new sportlines and just replace the rears and sell the fronts. Because the front springs i have on there now are fine. I also did not know if it was a good idea to just replace the rear springs with the Eibach Prokit springs. That way it would raise the rear a little. Them I would have the sportlines on the front and the Prokits on the rear. My plan eventually is to get the Bilstein BTS suspension package, but I need to fix this problem until then. Please let me know something ASAP. thanks everyone.
Old Dec 4, 2006 | 09:05 AM
jimmyblue's Avatar
Moderator
Check that the spring isolators and springs are
located, rotated identically side-side. Or maybe
you got a "grab bag assortment". Heh.
You can mix-n-match springs axle-wise. I have
stock in back minus donut and Hotchkiss in front.
Old Dec 4, 2006 | 12:08 PM
rocket22's Avatar
the problem isn't the the springs so as the shocks,Bilsteins don't have the damping needed for that drop,I have the same problem with a pro kit,I come to conculsion that the rear shocks need a lot of rebound to set the car faster.I have done quit abite a researsh and the only real way to fix is it with some $$$$ shocks like Koni's,or you might try some of Strano's revalve Bilstiens there cheaper,that's where I am at with my car,trying to decide what set-up to go with.
I did have someone suggest getting an air bag put in the right rear spring,I haven't tried it,but they say it works.
Old Dec 4, 2006 | 12:17 PM
But why is it just the one passenger side and not the driver side? If the shocks do not have the rebound needed wouldnt both rears be low? I adjusted the panhard bar a week ago and it leveled it out some, but then I changed to newer control arms and now it is back down.
Old Dec 4, 2006 | 12:36 PM
jimmyblue's Avatar
Moderator
Check too, that there is not something funny
about the sway bar endlink heights, sway bar
way off center, etc. Sway bar bent torsionally
or different-length links can bias the roll. Maybe
just disconnect the links and see about that.
If you are hitting the bump stops full time I
wonder if a shock may have been tweaked, some
do not like overtravel (well, I guess none do but
the travel limit for bent probably varies).
Old Dec 4, 2006 | 01:34 PM
rocket22's Avatar
Good question and that's one I haven't figure out yet either.These car set lower on the pass side anyway,I hadn't thought about sway bar links in the rear,I mite try that myself.
I have tried alot of differnet combo's.
Switched every side to side.
Took the isolater of the drivers side, left it on the pass.
but stock springs in, drivers w/o isolater,pass with and the car still sit's high on the drivers side.
It's a mystery to me,But to keep it of the bump stops it needs rebound and comperssion for that fact.
i understand your problem,I'm dealing with it too
Old Dec 5, 2006 | 08:59 AM
Does anybody know what the hardest springs are? I am looking for stiff springs that will also lower the car in the rear about 1.25". It has to be a problem with the rear spring, because all of the other 3 corners are good, it is just the passenger rear. So I am just going to replace the one rear or both rears i guess. I mean I am out of ideas.
