Deciding on lca's - opinions?
Car is a 99 Z28 A4 bone stock suspension
What im trying to accomplish is better traction/no wheel hop.
I DO NOT want my handling/roadholding to degrade, but i'm not necessarily concerned with seeing an improvement in handling, though it would be a plus.
After scanning some threads, including this one: https://ls1tech.com/forums/showthrea...&highlight=lca i seem to be reading that poly bushings are not the best in the twisties and that 1le rubber may be the way to go. Will going with poly ends actually degrade my car's handling... i dont care if they dont cause an improvement around the corners, i just dont want to make it worse.
Also, I saw the lakewood square tubed lca's are relatively cheap compared to some of the umi, sphon, and bmr examples. What accounts for the price difference if i do go with an aftermarket lca with poly ends. ( http://store.summitracing.com/partde...5&autoview=sku )
i had the lakewood on my 92 and they are tight, you can feel the difference especially if you do the panhard bar too... i have UMI tubulars on my 02 and they work good... either way they wont break the wallet, but if you lower the car, you will need LCA relocation brackets to keep the geometry right, weather they are bolt in(still get welded) or weld in and definatly an adjustable PHR
The added bind will prevent the appropriate articulation of the rear axle which is needed. In short there will be less range of axial motion compared to the 1LE bushings. Even though rubber will get worn over time, Poly will creep (otherwise known as coldflow), which I feel is okay in a location that doesn't need much movement (e.g. trans mount, engine mount, swaybar endlinks), however the LCA's, PHB and other similar locations which can use a great amount of axial movement will eventually permanently distort the poly bushings in those areas, which will lead to their eventual tearing as well.
Also, be aware that quite a bit of aftermarket LCA's are heavier than stock. While I don't mind added strength, I do mind added strength added uncessarily while increasing weight on the LCA's, and the LCA's weight is mostly unsprung. Adding more unsprung weight than necessary also harm's suspension reaction time as well.
While I have noticed that the OEM LCA's might not be the best for "really brutal motorsports", they've fared quite well in many AX, and even some RR. The real problems with the factory "star" bushings are not only their age (most of the LCA's on the cars are most likely not replaced by a new OE or OS part, but rather the actual OEM), but the fact that the "star" design doesn't make for good handling due to "less bushing material" present.
UNDER PRESSURE MOD
Great post Foxxtron. I recently switched back to stock lca's from poly/ploy lca's and notice the car handles better and the rear is much quieter now.
My quesiton is where can I buy just the 1le lca bushings? I don't need to buy the entire control arm, just the bushings.
Thanks.
Thanks.
Since you're in PA, you could call stranoparts. Even many around consider them "1LE", I believe they're most likely manufactured by Harris, which supplies to AC Delco, Moog chassis parts, TRW, and several others. I believe that the "1LE" designation sticks in people's memory since almost every bushing on the later (and possibly earlier) 1LE's had the more "complete" bushings as opposed to the "relieved" bushings in non-1LE's.
I believe also autozone might have them as well (maybe under one of their brand names possibly?)
UNDER PRESSURE MOD
Originally Posted by rocket22
I have poly and it corners great,no flex at all.
The problem with 1le's is they aren't a solid bar lca,they are u-shaped like a regular lca on a F-body.
GM knew what they were doing back in the mid to late 80s when they came out with these 1le optioned cars. They were amazing road racing platforms.
Just purchased a set of UMI tubular adjustable (single) (poly one end)(QA rods on the other end).
If you want the compromise, I'd suggest these! Dual rod ends can create some unwanted noises, whereas you can have a quieter ride and still some grab IMO.
My car is "bolt on" only at the moment, and since the torque arm upgrade, I've had no wheel hop issues to speak of, but everyone recommends aftermarket LCA's.
http://umiperformance.com/2016.aspx
I definetly recommend a rod ended PHR. As far as the LCA's go a rubber/rod may be the best compromise. There are also these newer design models.
https://ls1tech.com/forums/suspension-brakes/617994-lca-gimmic-not.html
I'm curious about how good they are.
