10 Bolt + BMR Rear Suspension = Noise
Anbody else expirience a noisy 10 bolt rear end with tubular BMR control arms, weld on brackets, adjustable ph rod, sf connectors? They have poly bushings, but just curious if it is normal for all that damn road noise.
Originally Posted by 94z28L
that kind
Wait until you go with all rod end front suspension. I'm used to it and the benifits definitly out weigh the noise(for me). You will probably notice it more when you brake. This is normal, but like stated above check to see if everything is still tight. After I install any new suspension/chasis parts I like to go back after a few hundred miles and torqe everything back down.
-William
-William
LS1Tech Premium Sponsor
If you are still having problems give me a call and I would be glad to lend a hand trouble shooting the issue
Lee Spicher
lee@bmrfabrication.com
(813)986-9302
Lee Spicher
(813)986-9302
Lee Spicher
(813)986-9302
Lee Spicher
(813)986-9302
Great, I will look at it this weekend double check the bolts and take it for a ride.
