Torque arm ?
Old Dec 4, 2006 | 04:47 PM
68LS1WANNABE's Avatar
Default Torque arm ?
On the adjustable torque arms why is there 2 bushings on the front mount. It looks like rear leaf spring mount for the 2 poly bushings. Does this allow the TA to move forward and backward? Why not just a single mounting point with a rod end?
Old Dec 4, 2006 | 04:55 PM
MeentSS02's Avatar
Kleeborp the Moderator™
I'm not quite following you...there are two rod ends towards the rear of the arm so that the mount itself can rotate the rear end about its long axis. If you only had one rod end and the other was fixed, you wouldn't be able to adjust it at all without bending the arm itself.
You only adjust one of the ends though (the bottom one usually).
Old Dec 4, 2006 | 06:49 PM
94z28L's Avatar
it depends on the torque arm you are lookin at madman's doesnt but his also has multiple moutning points on the front, its for ease of adjustability
Old Dec 5, 2006 | 09:07 AM
BMR Suspension's Avatar
LS1Tech Premium Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
The torque arm and the lower control arms travel on 2 different arcs. The "hinge plates" allow for the torque arm to move back and forth to follow the lower control arm arc and prevent binding.
Lee Spicher
lee@bmrfabrication.com
(813)986-9302
Old Dec 5, 2006 | 08:07 PM
that's what i was thinking. thanks for the clarification.
Lee Spicher
(813)986-9302
