Want to lower 1 to 1.25 inches but want BETTER RIDE!
I want to lower 1 to 1.25 inches but want a better ride.. I have 285/30/20 in the back and 255/35/19 in the front... I dont mind spending a little money....
I would say:
Koni Single Adjustables
Hotchkis Springs
Then don't forget the adj. panhard bar and relocation brackets. Adj. torque arm is optional but needed if you want to fix your pinion angle just right.
Hotchkis Springs
Don't know if you can get there from here, but Sam Strano is the guy to ask. Let him know your exact parameters as far as type of ride and lowering expectations.
He's the person who'd be my first choice.
sTeve
sTeve
Very doable I'd say. But I don't know any details about what a BETTER RIDE means to this gent.
The wheel/tire combo isn't doing you any favors. No sidewall and more unsprung weight is a double-whammy. But the shocks are certainly an issue, and they effect ride more than springs do. In short I'm saying the right springs and shocks (and I think I have those) will make the car ride much less harshly. Not softly, but not as slam-bam as it does not, not by a long shot.
__________________
What about it? If you want to spend a fortune on a setup with junk shocks and unknown spring rates (and ones that vary depending on height which is dependent on air pressure), then sure...... I'll pass, because the lower you go, the MORE rate you need, not less. And to go lower, you lower the air pressure and that results in LESS spring rate.
__________________
I've just never had good luck with lowering a car and maintaining a "good" ride. Again not saying it isn't possible, but niether of my F-Cars ride "nice" They handle awesome, but ride?
I know you are the man to listen too for supension upgrades, so beleive me I'm not questioning you.
And I certainly didn't mean it to sound wrong if it did. I just tend to want to make sure folks understand.
__________________
Originally Posted by Xsta Z 28
Just throwing out a suggestion . . . . Not saying it was good or bad.
1. Cut springs or "slammed" aftermarket springs that are about setting the car on the bumpstops for looks and not improving ride and handling.
2. Stock or cheap aftermarket shocks that can barely keep up with stock springs, much less lowering spring rates.
The important thing is to get a quality spring thats not too low and a good shock that can keep up. I suggest Koni SA's and any of the springs that get good reviews on this board. DMS, Hotchkis, Strano, Pro Kit (no sportlines), and so on. But with the Koni's you could just about put rubber blocks in place of your springs and improve the ride over stock.
Originally Posted by Silver UltraZ
Alright Mr Srano.. Whats the good word? Whats a good setup?
-Mike
