LCA Relo. Brackets?
If you are having problems with wheel hop on a lowered car, and nothing else fixes it, the brackets might be the ticket. I can neither confirm nor deny their effectiveness though from my own personal experience.
the majority opinion depends on aplication
for drag racing, yes these help you can also use reloc brackets to get a better angle of attack on the ground
strano seems to be god here, but even he recomends them for straight line performance
these will help with traction on a normal height car aswell as a lowered car, on a lowered car they are a must becuase of the change in angle
95 Pontiac Formula- Stock engine with ATI Procharger, Moser 12 bolt w/4:30 gears, Rossler trans, Neil Chance 4000 stall, M/T ET streets, 10.914@ 121.90mph, 1.452 60ft. GMHTP November 2010 Feature Car. Check it out at:
https://www.motortrend.com/features/...ebird-formula/
http://www.youtube.com/watch?v=abZ1z...ature=youtu.be
i bought relos, and brought them back to horizontal..the feeling was literally "seat of the pants"....i didnt realize how bad it was until i adjusted them...
I say if you lowered get em(but only if your LCA's need adjusting)...if not, they are not neccesary at all
Im making good power as the car sits now. I get massive wheel spin in first if I really get on it, but its smooth...no hop. If I nail 2nd real hard, I get a squawk from the tires sometimes...but they dont break loose.
My car is lowered 1" with a pro-kit, has bilsteins all around, and my rear control arms are pointing up towards the rear at a pretty good angle.
My limited knowledge tells me I should be having some wheel hop...and at the least limited traction in the back. But I seem to have no wheel hop, and decent traction. I have the relocation brackets sitting on my bench ready to go on. But Im just curious if you guys think it will even make a difference???
I just havent seen the issues that some see with a lowered car, decent power, and no relo. brackets.
Justin
Hehe dont worry...Im puttin them on. When I go to service the rear this winter Im going to weld em in.
J.
good luck let us know for sure!
