Pulling hard under heavy braking
Sometimes not all the time my car will pull hard to the left or right under heavy braking....other times (also not always) while im cruising if i let go of the wheel ill start mosying to the right a bit...this just an allignment problem or something more?
get a good 4 wheel alignment, check your pressures, and you may want to rotate your fronts to rears, if possible, before the alignment. if it was that far off, you could have gotten uneven wear on your front tires, which will affect your new alignment. its best to have either new, or evenly worn tires on front when getting one.
Copy & Paste Moderator
If the alignment doesn't solve the problem, then there might be something wrong with a caliper or brake line. But that would be the case if it always pulled to the same side. Also check the sway bar end links and maybe the tie rods.
