lowering springs without shocks?
Copy & Paste Moderator
I guess it got moved. Sweet
I didn't realize there was a forum for suspension.
what is the cheapest aftermarket set of shocks I can get for a 1.25"-1.75" drop?
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
I do *not* recommend doing this. From personal experience, it's not a good idea - poor ride and handling.
I had stock shocks with Eibach Sportlines. It turned pretty darn good but it was a really bouncy ride otherwise. I would definatly reccomend doing shocks and I wouldnt really reccomend sportlines because they are a little too low and you`ll hit bump stops like mad.
Who here has lowered there car without buying shocks??
What kind of drop, and how bad is the ride?
![The Judge](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_judge.gif)
I now run the same springs but with Koni DA shocks and the car feels great!
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
So don't waste your time with the stock shocks, they suck to begin with and will quickly be completely destroyed with higher spring rates found with lowering springs.
Greg
tonight I noticed it looked like I have aftermarket shocks under my car. when I bought it he said it had "custom air shocks dropped 2"." Question is, can I now install lowering springs and not have to worry much about getting new shocks?
Most likely no. Sounds like he did not know what he was talking about IMO. What do the shocks look like? (color, stampings, adjustment *****, air hoses or valve stems on them?)
I've never hear of "Custom air shocks" except for the ones from AIR RIDE which require an onboard compressor, valving and gauges. You would definately know if you had those or not so, no don't run what you have and get some quality shocks before lowering. You can thank all of us later.
I've never hear of "Custom air shocks" except for the ones from AIR RIDE which require an onboard compressor, valving and gauges. You would definately know if you had those or not so, no don't run what you have and get some quality shocks before lowering. You can thank all of us later.![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
