18"z06 2 inch Drop?
Originally Posted by 99Transamls1
does anyone have any pics of a trans am with 18 z06 with a 2 inch drop
Man, if this is for your car, then I'mma gonna feel sorry for you and your LT's, as they're going to be scraping BIG TIME!
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
Originally Posted by Carlos01SS
Are you planning on dropping your vehicle that low with the 18" wheels???
Man, if this is for your car, then I'mma gonna feel sorry for you and your LT's, as they're going to be scraping BIG TIME!![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
No problem!
Im not even lowered and I scrape bad on bumps if I go too fast over them.. It scrapes hard and sounds like death.... But Ir just hits my LM resonator or my clamps. My ORY or Lts dont scrape..
Originally Posted by 99wssixm6
18 inch wheels will raise the frame/exhaust .5" higher than if it had 17" wheels.
That's the funniest thing I have read today!!
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
Wheel Diameter has nothing to do with raising or lowering a car, It's the height of the tire sidewall or the tire OD that affects the ground clearance.
It's called Plus 1 or +1 sizing where you go up 1" in wheel diameter but go down to a lower aspect ratio tire so the wheel gets bigger but the tire OD does not change at all, thus the ride height doesn't change. (nor does your speedometer)
example >> 275/40/17" tire has the same OD as a 275/35/18" tire so no change in ride height.
18 inch wheels will raise the frame/exhaust .5" higher than if it had 17" wheels. I do have my ws6 lowered with the pro-kit and have 18's. The y-pipe hangs alittle low and does hit occasionally but mostly on the clamps and brackets; nothing on the headers.
Take this for example. The tires and wheels I had before versus what I have now and their overall diameters.
275-40-17 - 25.6614" tall
275-35-18 - 25.5787" tall
Yes I have a 1" larger wheel now. Yet I still have the same width tire and virtually same diameter. Please do your research before you say something like that. Giving someone wrong information like that could cause an un-knowledgable person on the subject some real problems.
Originally Posted by Bigrob339
Here is my TA with 18" Z06 rims with the pro-kit and bilsteins, its close if not more then 2" drop.
![](http://i11.photobucket.com/albums/a177/bigrob339/100_0697.jpg)
![](http://i11.photobucket.com/albums/a177/bigrob339/100_0694.jpg)
lata rob
lata rob
Second, are you running stock manifolds, or some sort of a header? Any problems with ground clearance?
I am running Pacesetter headers with ORY and Borla exhaust. I will be eventually changing the headers 2 Kooks but that is next year prolly. But no clearence problems, i can get over most stuff, only thing is speed bump if i hit the straight on it loads the suspension all at once and it scrapes a little (If you get what i am tryin 2 say), so i take all bump at a angle now and have not had a problem.
peace rob
peace rob
peace rob
peace rob
