adj panhard bar ???
As the car rises and fall, due to bumps in the road, the rear axle pivots in an arc around the bar's mounting point. This is why the body shifts back and forth, in reaction to the bar's rotation. (You don't see it because you're in the car)
Raising or lowering the car with different springs has the same effect as hitting a bump in the road. The body of the car moves about the pivot point of the bar, except the body stays still, just offset somewhat. The purpose of the adjustable bar is to compensate for the modified body height (ride height) and allow you to get the car re-centered over the rear axle.
Here's a quick way to see if your front and rear wheels are tracking correctly. Wet the street in front of your house (assuming it's straight). Drive STRAIGHT through the water, then get out and note the tire tracks.
If the rear is too far to the right, you'll see patterns like this:
If it's too far to the left, you'll see patterns like this:
Then you can make adjustments accordingly. Too fix it if it's too far to the right, you need to lengthen the bar (push the axle mount farther from the body mount). Of course, if it's too far left, you need to lengthen the bar (push the axle mount away from the body mount. If you look at the picture Ryan (UMI) posted, you'll see what I mean.
If your lower control arms aren't the same length, it would look more like this:
-Mike
