need help with my supention drop
hey yall, i have a 01 ws6 with a elback pro kit on it... switching back to stock for now. hear is were i need help. i still want a drop somthing like 3/4 of an inch. what can i do to the factory sup to achieve this goal... thanks
With the fronts and factory shocks, your only real option is to cut the springs. Probably not a good idea if you're keeping the stock shocks, as you'll end up witha crummy ride. In the back, you can do the "heater hose mod", where you remove the big rubber isolator from the top of the spring, then wrap the first coil in 5/8" heater hose (to keep from a metal on metal chatter).
-Mike
-Mike
