its leaning to the pass side
Old Jan 16, 2007 | 10:22 AM
95formulalt1's Avatar
Default its leaning to the pass side
what should i do?? its leaning to pass side in the rear. i just lowerd it wioth new shocks and springs. would a adj Panhard Rod help??? ??
mike
Old Jan 16, 2007 | 11:22 AM
Out1aw's Avatar
Get a level and put it up to the side of the rear tire on the inside and see if it is off any. If so it's because your rear-end isn't aligned and an adjustable PHB would be needed.
Old Jan 16, 2007 | 04:03 PM
Yahelou's Avatar
actually, my car was doin the same thing b4 i changed the shocks/springs. it was leaning about 1.5 inches. put in the new shocks/springs, its still there but not as bad and noticable. the stock springs on the passenger side were more compressed than on the drivers side. It turns out that the old owner before me hit a curb or something , and thats what caused that.
Old Jan 16, 2007 | 05:41 PM
gun5l1ng3r's Avatar
My drivers side is actaully lower than the pass. side. My brother ran my car sideways into the curb and I think when they replaced the lower rear spring perch, I think it was put on at the wrong angle.
Old Jan 17, 2007 | 09:46 AM
1QUIKWS6's Avatar
Active Streak: 30 Days
My 2000 T/A has sat lower on one side than the other from when it was delivered new. Has 35k miles on it now, never been wrecked, has an adjustable PR, and it still sits the same way.
The Adj PR was only installed to properly center the rear after I installed the 17x11 wheels out back. Don't see how that would correct ride height?
Old Jan 17, 2007 | 04:57 PM
i got something that bolts on the spring like a spacer but you can adj it so i will give it a try to see how it works!
Old Jan 17, 2007 | 05:21 PM
WS6 SRT-8's Avatar
[QUOTE=1QUIKWS6]My 2000 T/A has sat lower on one side than the other from when it was delivered new.
Mine too. I guess it's more common than I thought.
Old Jan 17, 2007 | 05:42 PM
cakweems's Avatar
My o2 Z28 done the same thing and i bought an air bag from thunderracing and it took care of the problem.
Old Jan 17, 2007 | 05:44 PM
DrEvyl's Avatar
teh PuRpL3z
I've never seen an F-body that didn't lean to one side slightly. Both of mine do as well.
Old Jan 17, 2007 | 07:46 PM
ya mines almost looks like its sitting on the tire!! but i have not driven it yet. it should drop more when its driven right??
