i hate my brakes...
a little over a year ago i put on new rotors and pads but they squeeled from the very beginning and progressively got worse...a month ago i noticed from stop to roll a sqeek every time my front passenger wheel rotated but as i got to around 20 mph it went away all the time it seemed everything squeeled when i applied brakes...
a week ago i changed my pads cuz my rotors seemed fine no warping from i could tell and they were quiet...but now im getting worse squeels from my brakes than before...
whats the deal? any help?
its gonna happen when u put new pads on rotors that have worn to other pads.you got 2 surfaces that are not on the same plane, also the edge of the pads r making contact w/ a little lip made by the other pads.cut the rotors,bevel the edge of pads,& lubricate the hardware.give that a try and it does not correct the noise, try a differant brand pad.
Originally Posted by toofless916
naw semi metallic on some cross drilled slotted...yeah i used break cleaner
