Billingsley Manual brake kit ?
I went to install it and it has a 1/2 inch gap under it from the booster hole, is this right? Also it doesn't line up with the old linkage post on the pedal, am I suppose to drill a new spot for it?
thanks
thanks
Yep, it takes a new hole in the pedal arm, about 1" above the original hole.
I put a piece of thin aluminum plate behind mine to finish covering up the hole in the firewall. Made a template out of thin cardboard first, and made sure it didn't hang up anywhere it wasn't supposed to be.
